-   -   GPS Fix Lost (http://www.sailnet.com/forums/gear-maintenance/33895-gps-fix-lost.html)
maddata 06-21-2007 11:58 AM
GPS Fix Lost
Has anyone had any issues with a Raystar 125 GPS receiver failing or losing its fix permanently? Mine (mounted on the sternrail) worked for a few weeks and now will not receive a fix. I tested the connection and the sea talk box is receiving and transmitting other data to my chart plotter (a C70). So, I figure the issue is a hardware failure with the receiver. The only issue is the GPS receiver blinks green as if it has a fix, but again, no data comes to the chart plotter.
Sapperwhite 06-21-2007 12:01 PM
I think i remember reading about this type of senario in a thread called Celestial Navigation?....Forget It! I don't have an answer for your problem, sorry,, but this is a case in point for that other thread.
labatt 06-21-2007 02:02 PM
I have been having this problem on and off with a 120 series GPS receiver. If I power the receiver off and back on (the chartplotter is irrelevant) it comes back. I haven't been able to track the gremlin down. The only pattern I can find is that it fails at the most critical moment.
Boasun 06-21-2007 10:11 PM
This is why you need to know how to navigate.
Have had about three GPSs quit on me. Then we toss them and get a new one. Then you have the joy of re-installing all of your way points. You do have the way points in your navigator's work book right!?
I for one practice and teach those "archaic" navigation skills. You will be surprised on handy those skills are in everyday operation of you boat, even if you are using a GPS.
sailingdog 06-21-2007 10:19 PM
That would be Murphy. :D
Boasunó
Just FYI, most GPS units will allow you to save waypoints to a memory card or computer... so that you don't have to manually enter them over again. This is probably the way to go, since manually entering them allows the chance to royally screw them up each time. :D
Maddata-
Does the Raystar 125 output NMEA 0183 or Seatalk? If it outputs NMEA 0183, you could always put a computer's serial port on it and see what data is actually being passed. That would at least tell you if the Raystar 125 is actually getting a lock and transmitting the proper data. If it is, then it is likely that the display is the issue. That sounds far more likely IMHO.
If it transmits only in Seatalk, you could use a NMEA 0183 multiplexer, since there is at least one out there that can translate Seatalk into NMEA 0183.
labatt 06-21-2007 10:20 PM
I usually sail by chart and compass, but I'll use the GPS to verify our location and our cross-track error. When I'm going 50-60 miles between turns, if you're off by a few degrees it can mean a bunch of extra time. If I was doing 150 mile days, I'd want it even more. So anyway, navigation by chart, verification by GPS, for us... But it still doesn't fix the problem of the mysteriously disappearing sensor...
sailingdog 06-21-2007 11:07 PM
Labatt-
Much of what I wrote for Maddata would probably apply to you. ;)
camaraderie 06-21-2007 11:36 PM
Sapperwhite...
Yeah...it belongs on the part of the thread where I said you need multiple GPS's. A Celestial Fix on lake champlain will put him somewhere in the adirondacks..since it is pretty darn hard to get a horizon there!! (G)
<!-- / message --><!-- controls -->
sailingdog 06-22-2007 08:19 AM
I generally don't recommend Celestial Navigation for inland sailing.. LOL
Sapperwhite 06-22-2007 08:46 AM
"A Celestial Fix on lake champlain will put him somewhere in the adirondacks..since it is pretty darn hard to get a horizon there!!"
In Labatts case, yes carry an extra on board, maybe just a nice handheld with all the bells and whistles. But, I have seen screenshots of a chartplotter showing some boat to be about 300' inland when they were actually tucked safely in the slip, so GPS isn't foolproof. Sorry about not knowing Labatts cruising area.
However, where is Maddata sailing when his GPS turns into a field improvised doorstop? Half way to Bermuda maybe???? I don't know. All I'm saying is that the Polynesians didn't settle the south pacific by carrying extra GPS units with them. Magellan didn't get where he was going by having the latest toy loaded with his favorite tracks and waypoints.
Sorry for hijacking the thread, hope someone can help you guys with the technical problems.
