06-21-2007
The capacity varies with the discharge rate, which is why they give you twp sample cases:
280 minutes at a 25 amp rate, and 102 minutes at the 56 amp rate.
Read a few columns further and they also show you "5 hr rate AH 120" and "20 Hr Rate AH 150".
Meaning, if you drain the batttery 100%, you can suck 120 amp hours out of it in five hours. But if you don't suck as hard, you can pull 150 amp hours out of it. That's normal for all battery types, to supply more power under lower demand rates.
Remember those are also 100% discharge rates, if you're planning to cycle the batteries to 40-50% depth, cut them down to match.
