Old 06-21-2007
calamitas is on a distinguished road
mysteries of outboard motor behavior
Here's a newbie question for y'all:
I have a 9.9 hp Yamaha outboard on my boat. I recently replaced the fuel line with squeeze bulb to resolve a no-start problem. Now it starts every time with the push of a button! Then it runs for 10-20 minutes with no problems, then it dies. At which point I open the locker and squeeze the bulb a few times and then it starts right up again and runs for 10-20 minutes and then dies. Repeat...
So, why does it do this?
Old 06-21-2007
hellosailor's Avatar
Mmmm...Did you open the vent screw on the fuel tank? (Don't ask me why I know this.)
Any pinholes or cracks in the fuel line or conenctions, that are letting air get into the line and breaking the suction to the fuel?
Old 06-21-2007
Second the idea of the vent, or possible air leaks...
Old 06-21-2007
bentmast is on a distinguished road
Check the filter(screen) on the inside of the tank.
Sounds like it might be plugged up.
Old 06-21-2007
If you have opened the vent, then my guess it is the carburetor or the fuel filter. Another possibility is that you have an air leak in the fuel like... a common place for this to happen is the banjo bolts in the fuel line.
Old 06-23-2007
Thumbs up thanks
Thanks, everyone. This forum is a great resource. Yes, the vent cap is open while motor is running. I will check for possible air leaks, clean the intake screen, and replace the fuel filter.
Old 06-23-2007
Water Junkie
LaPlaya is on a distinguished road
Although with it restarting so quickly it does not seem likely that it could be overheating, but is the waterpump working?
Also when you squeeze the bulb is it hard?
AL
Old 06-23-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
It may also be a bad fuel pump, but I would bet on a bad quick-connection first.
Old 06-23-2007
Did you do any maintenance on the engine prior to this recent bout of usage? If so, did you touch the fuel lines in anyway.... if so, likely you overtightened a banjo bolt and mangled the copper washer, and it will leak air.
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Reputable websites from which to buy outboard parts? Chompy Gear & Maintenance 4 05-04-2010 02:41 PM
Inboard vs. Outboard greencaptn Boat Review and Purchase Forum 19 02-20-2007 08:05 AM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
