06-21-2007
Inside-outside DC blocks are used to prevent ground loops. I doubt seriously if you need one. Your mast is grounded and, by extension, so is your standing rigging. Presumably, your boat's DC ground is also connected to seawater and, perhaps, to the mast directly.
I've never seen a situation on a boat where such a device was needed, but I haven't seen 'em all :-)
Suggest you run the RG-213 and forget about the block. BTW, they introduce some attenuation and up to 1.4 or 1.5 SWR to the RF signal....not desirable.
Bill
