The Dremel - Page 2 - SailNet Community
post #11 of 21 Old 06-22-2007
Here .. Pull this
I still prefer my Mastercraft rotary saw. All of the Dremel heads fit into the flex tool and it's a lot more powerful.
Sailormann is offline
post #12 of 21 Old 06-22-2007
moderate?
camaraderie's Avatar
Dawg...
LOL... another person realizes that it ain't all about power and size...
Why do I get the feeling you NEED that to be true!
camaraderie is offline
post #13 of 21 Old 06-22-2007
I'd rather be sailing
labatt's Avatar
Originally Posted by TrueBlue
Last weekend when detailing the boat though, I was trying to remove some surface crud and corrosion on aluminum, bronze and stainless fittings
I'm going to be using my dremel this weekend to clean some bronze fittings on deck. Which attachment worked best? Do you put anything on the fitting or just clean it up dry? I'm very new at this
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #14 of 21 Old 06-22-2007
Señor Member
TrueBlue's Avatar
I used a polishing brush attachment for most metalwork . . . brass and stainless bristles. Avoid mild steel bristles, since the bits will become embedded in fiberglass - resulting in rust specs which are very difficult to remove (Don't ask how I found this out).
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #15 of 21 Old 06-22-2007
Grampian 26 Owner
sidiag's Avatar
Don't need to - Already found out for myself .
Regards,
Stan G.
s/v Tryphena a '74 Grampian 26
sidiag is offline
post #16 of 21 Old 06-22-2007
pigslo's Avatar
The key is using having the right tool for the job. EX: A saber saw and a circular saw each cut and may overlap but each has a place.
pigslo
pigslo is offline
post #17 of 21 Old 06-22-2007
moderate?
pigslo
Example...for making pork sausage...the right tool for the Piggy!
Stainless of course for marine use. Good to see ya Pigs!
post #18 of 21 Old 06-23-2007
Owner, Green Bay Packers
The key to happy Dremel ownership is to buy the over-priced POS when you don't need it for a specific project. Buy all the stupid attachments at the same time-the Ryobi version are cheaper. Then throw it in your tool chest and forget it. If you buy it for a specific job it won't work for that job and you'll be pissed you spent the money. But, if you have it, you'll find that it is just perfect for a job every couple of years or so, and you'll throw it back in the box happy you had it.
I know this because I bought mine in 1984 and have used it, maybe, a dozen times. And it DID do a credible job of cutting out the pilot bearing on a Mazda RX-7 flywheel. The other eleven times were those classic cases where I had no idea how I was going to accomplish something and suddenly remembered the over-priced POS. It didn't always work, but at least it's easier to find in the tool chest than an electrical three prong to two prong adapter.(g)
Wm. F. Buckley, Jr.
sailaway21 is offline
post #19 of 21 Old 06-23-2007
pigslo's Avatar
Cam, that looks like the devce that killed my uncle.
pigslo
pigslo is offline
post #20 of 21 Old 06-23-2007
Alex, not full of crap
werebeagle's Avatar
And he tasted good pigs
Charlie
Courtney's my Dancing Angel
Where am I, and where's my paddle?
It's not impossible, it just costs more.
Give me ambiguity, or give me something else.
werebeagle is offline
Dremel--Show Me the Love! geary126 Gear & Maintenance 30 05-03-2007 06:48 PM
