06-22-2007
Actually, while GPS's are generally accurate, but not always... even when they are accurate, they may not be accurate to the paper charts... since the paper charts, like those in the chartplotter, are only as accurate as the tools used to make them. Also, the chart datum of the charts may not be the same as that of the GPS, and if you're using two different chart datums—one in the GPS and one from the chart—you're introducing a fairly significant source of error.
