Does this mean a head rebuild? - SailNet Community
Blogs
Old 06-23-2007
I'd rather be sailing
labatt will become famous soon enough
We have a PH2. When you pump it dry, it refills with disgusting water (that looks like it's from the holding tank) over the next 10-15 minutes or so. Does this mean I need to rebuild the head? Or is it something worse?
Thanks!
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 06-23-2007
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
As disgusting as it is, some heads are actually plumbed to "flush" with the liquid from the holding tank. I had one like that once. Never could stop from getting creeped out by it.
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
Old 06-23-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
You may want to have a look at the March/April 2006 Good Old Boat. It has a great article and diagram on "rethinking the head".
Paul
S/V Scheherazade
Old 06-23-2007
ebs001's Avatar
ebs001 is on a distinguished road
Sounds like you need a new joker valve. No joke, its supposed to stop the holding tank contents from flowing back into the head.
Old 06-23-2007
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Here's a second vote to replace the joker valve. If it shuts properly, nothing should be coming back in. Sounds like it's full of crud (calcified probably) and needs to be replaced.
A lovely job, but someone has to do it.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 06-23-2007
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
PH II Exploded View Diagram
Labatt,
Here is the link from Raritan for the parts list and exploded view diagram of the PH II. If the joker valve becomes distorted in any way then it will allow fluid to feed back into the bowl. Before you rebuild the head, flush PLENTY of fresh water through so you don't get and back splash of the "good stuff". I have a WC , so I don't know if you can buy just the joker valve from Raritan. However, if you are fixing one part, you can bet that the other parts will go soon too. Once you get into a job like this you might as well replace all of the "consumable" or replaceable parts. Buy a full rebuild kit, or a whole new head unit. Sometimes the cost of the whole thing isn't all that more expensive than the rebuild kit. It's a matter of cost vs. convenience I guess. Check this link out either way (its a .pdf). Have fun, and remember to purge the thing with lots of water prior to taking it apart.
http://www.raritaneng.com/pdf_files/...Ephiiv0303.pdf
Old 06-23-2007
camaraderie's Avatar
moderate?
It's the joker valve. You don't need a whole rebuild kit unless other stuff is not operating properly but it is hard to find just joker valves at the local marine stores so you may end up buying a rebuild kit. Just tackle the joker first and if everything works...save the rest of the rebuild kit for when something else goes bad.
Old 06-23-2007
can't re member
yotphix is on a distinguished road
I don't doubt that you are correct but...huh?!? How does it make sense to flush sewage with sewage? The whole point is to put sewage into the tank and out of sight/smell. Any head plumbed this way should be replumbed immediately. That's just dumb!
Old 06-23-2007
You won't be able to get just the joker from a marine store. You will have to order it from the OEM, Raritan. I've bought single parts from WC off of the parts list. Just be prepared to pay more for shipping than the cost of the actual part.
Old 06-24-2007
It's also possible that something has simply gotten stuck in the Joker valve preventing the sides from sealing - a simply removal and cleaning may do the trick.
Head Service Kit (Jabsco) offline2004 Gear & Maintenance 6 04-16-2007 12:39 PM
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 08:00 PM
Head Problems bootsy1962 General Discussion (sailing related) 3 02-19-2002 08:26 PM
Head Maintenance Blues Tom Wood Gear and Maintenance Articles 0 11-21-1999 08:00 PM
Head Maintenance Blues Tom Wood Her Sailnet Articles 0 11-21-1999 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
