06-24-2007
I'd spend the money on new lines...since you don't know how damaged these lines are from being used for two years mostly unattended. Nylon weakens with UV exposure. It also weakens if strained too hard or overheated—both of which can happen in a bad storm. If the nylon is dry and worked under severe load, it can heat up enough heat-damage or even fuse the inner strands... which basically ruins it strength-wise.
