06-25-2007
Just remember to get a tank with thick enough walls to support the weight and bulk of the tank when full. Sewage weighs about 10 lbs. per gallon. Many commercially available tanks are a bit too thin-walled to safely support the weight of the contents... and in this case, that would be really bad.
I believe you will want a roto-molded Polyethylene tank, if you can find one in the right shape for your boat.
