what to check when buying a a4? - SailNet Community
post #1 of 2 Old 02-21-2002 Thread Starter
im going to look at an a4 thats for sale, what are some things that can be checked on these engines, this seems to be be an older engine do they hold up over the years? and what is a common price for running a4? thanks for any info.
rappitysnap is offline
post #2 of 2 Old 02-21-2002
Ask, Fresh or raw water cooling?
You want fresh, but raw is okay.
if you check this:
As you face the flywheel, on the left side
remove a bolt from the water jacket cover, at least three threads showing on the bolt? This is a gauge of water jacket corrosion. Three is minimum, 5 is good 7 is great.
Remove the spark plugs and check compression 80+ PSI all cylinders at cranking speed with the throttle full open?
The pressure reading should be fairly even on all the cylinders. This will show up stuck/burned valves.
When the engine is spinning with the plugs removed via the starter motor is there at least 10 PSI oil pressure?
This checks the lower end for bearing damage.
On a healthy A4 with 30 wt oil you should see
at least this. Possibly more.
Is the exhaust manifold in good shape? It''s water cooled, if it corrodes through you will get water in the engine.
How''s the oil look? Should have no signs of water having been mixed with. A bad water pump can cause this.
Good luck.
SOLFAN is offline
Buying a Catamaran...S.O.S. sailortaylor General Discussion (sailing related) 5 06-20-2008 12:55 AM
charter renting vs. buying baober Boat Review and Purchase Forum 6 08-24-2004 10:06 AM
Buying Hunter 340 eplante Boat Review and Purchase Forum 0 08-21-2001 01:12 PM
Best boat for buying and selling in the Med? dwooody Boat Review and Purchase Forum 0 03-12-2001 09:52 AM
Welcome to Buying a Boat messageboard Boat Review and Purchase Forum 1 09-14-2000 05:22 PM
