Handheld Wind meters - SailNet Community
Blogs
Old 06-24-2007
mikepxx is on a distinguished road
I seeking any thoughts, opinions, review, or experiences with handheld windmeters. Do they work and are they accurate?
Old 06-24-2007
I think most of them work reasonably well, and those that have a direction/bearing feature are more useful still.
However the readings obtained at deck level are likely not that of the true wind - first off it is apparent wind that registers, and the wind is usually a bit higher aloft than at sea/deck level due to some surface friction.
They also need to be aimed directly into the wind for maximum readout.
Old 06-24-2007
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
A. You can wet a finger and hold it up.
B. Get a look at the flags and see how they are flying.
C. Use an installed anemometer to get the Apparent wind.
D. Use a hand held anemometer to get the Apparent wind.
E. Spit into the wind and gage its strength by how hard it splatters back on your face.
(I've seen people with Mal de Mar let it go straight into the wind not a pretty sight.)
Now that you have apparent wind (Spd & Relative Direction) you derive true wind from it by using your vessel's spd & Course. Vectoring it on a maneuvering board is the easiest way to do so.
Have fun.
Oh! You could listen to the Wx report. But you all know how inacturate the weathermen are.
Old 06-24-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Hey, if it works for you,...use it....don't pay any attention to these yahoos on sailnet...but if wind speed is really important to you, put a windmeter on top of your mast for sure....;-)
Old 06-24-2007
The Kestrels have rated very well in PS, but use a small enclosed fan, so it needs to be aimed.
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 08:00 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 09:00 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 08:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 08:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
