Old 06-24-2007
henrystanley is on a distinguished road
my yanmar 2gm20 will not start
I replaced the prefiter on my yanmar , but today after running the engine for a few minutes , it stuterred and died . I suspected the problem was air in the pipes . I have bled the low pressure system with success - got clear diesel . and relaced the fine filter whilst bleeding the system . The high pressure system is another story - i followed what the manual says - this is meant to be simple ! - please help , i have spent all of today trying to fix the problem .I think am going slightly mad.
x
ta
Old 06-24-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Air in the high presure side is the most devestating. It will act like a spring and not let the liquid come up to required presure to move on. Look for a place to bleed off this air close to the nozzles or injectors.
Old 06-24-2007
Rickm505's Avatar
Rickm505 is on a distinguished road
When you say that you've bled the low pressure system, is that to the fuel bowl which houses the secondary filter or did you crack the input banjo at the injector pump?
Rick in florida
Old 06-24-2007
yanmar2gm20
Yes , i cracked some of the nuts along the fuel injection ( high pressure system ) , there is free flow of diesel as far as the low pressure end i.e where the fine filter leaves .I stopped here ,for fear of causing further, expensive damage .
ta
Old 06-25-2007
Thanks guys ,i got it working this afternoon - lunch time.The problem was onthe high pressure system , just after the fine filter .Its a great moral boost for me .
Lessions learnt
Know your stuff -
Get a manual and read it
To bleed , be systematic
Persevere- access to the engine parts can be difficult - you need to be a contortionist.
Have the right tools .
x
ta
Old 06-25-2007
Rickm505's Avatar
Henry
That's still low pressure there, and I need to do this as well with my Yanmars when changing secondary filters.
Rick in Florida
Old 06-25-2007
Whatever ! - i am just sooo relieved i got the engine working again.
x
ta
Can't start My Yanmar bun243 Gear & Maintenance 8 06-04-2006 01:22 AM
Yanmar 2gm20 won''t start Juebel Gear & Maintenance 6 05-18-2004 07:49 AM
Recovering from Bad Starts Dean Brenner Racing Articles 0 05-29-2002 08:00 PM
Adapting from the Match Race Crowd Dean Brenner Racing Articles 0 11-14-2001 07:00 PM
Ronstan’s Clear Start Dan Dickison Buying a Boat Articles 0 11-10-2000 07:00 PM
