06-25-2007
The excess fuel by the leaking injector would cause the cylinder to overheat.
BTW, just flushing the system may not remove a constriction, if the constriction is caused by a sediment build-up or broken impeller blade jammed in the channels, usually at a bend. The channel may allow enough water through, so it appears to be clear, but may be restricted enough that at higher throttle settings, not enough water is circulating to dissapate the heat properly.
