Yanmar 2GM intermittent low power - Page 2 - SailNet Community
post #11 of 22 Old 06-25-2007
absolutely. I had the same problem on the same engine. Sounds exactly like the problems that I had. Do yourself a favor. Replace it. It is easy if you remove the 4 bolts on the exhaust manifold, the elbow comes with it and the change the elbow out on a workbench.
puff6022 is offline
post #12 of 22 Old 06-25-2007
Rickm505's Avatar
Before you start spending $100s on engine parts. Change the Racor Filter. Remember, it's your primary filter. White smoke could be a sign of water in the fuel. When you go to the store to get the filter, ask them for a fuel additive to eliminate the water. It's only a couple of bucks.
You'll have to bleed again all the way to the input of the injector pump as you've done once already.
99% of the time, these two steps will correct the problem. If it doesn't then you can expand the diagnosis area and head for that mixing elbow.
Rick in Florida
Rickm505 is offline
post #13 of 22 Old 06-25-2007 Thread Starter
thanks for all of the advice. I will change out the racor tomorrow, and if that doesn't do it, look at the elbow!
Northeaster is offline
post #14 of 22 Old 06-26-2007 Thread Starter
As the boat is an hour drive away - have a couple of questions before I go:
My racor (don't know the model #) has the clear glass, with the drain at the bottom. I never looked at it very closely, just enough to see the fuel looked clear - boat is new to me - Could it just be a water separator, or do the clear ones always have a filter as well (I assume in the housing above the clear glass)
I called a local boat dealer, but they don't stock racor filters. They said to tyr a local auto parts store - they could cross reference the filter, and give me something similar. Does taht sound right? There are no marine diesel shops nearby!
post #15 of 22 Old 06-26-2007
rperret's Avatar
Just asked a similar question a while ago...
See link below to determine what filter you have.
MARINE FUEL FILTRATION
Where do you live - if in Northeast - try Mack Boring. Would strongly recommend you get from a marine supplier rather than auto parts - although a more informed person would be able to tell if auto and marine filter is the same.
To answer your first question - the filter is above the clear glass. The clear bottom is for seeing the water - water is heavier than diesel so would show seperation at bottom.
rperret is offline
post #16 of 22 Old 06-26-2007
Senior Moment
SailorMitch's Avatar
Waste (West to the uninitiated) Marine sells the Racor filters.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #17 of 22 Old 06-26-2007 Thread Starter
great link - Thanks very much. I am having computer issues, and couldn't search for Racor filters.
I am pretty sure mine is the 120 Series RMAM (diesel spin-on).
post #18 of 22 Old 06-26-2007
rperret's Avatar
aka Worst Marine
rperret is offline
post #19 of 22 Old 06-26-2007
RAGTIMEDON's Avatar
If you go to an auto parts store, go to one that serves a lot of trucks. Diesel fuel filters and gasoline filters are vastly different. I buy my primary filters from a Caterpillar dealer---never had a problem.
RAGTIMEDON is offline
post #20 of 22 Old 06-26-2007 Thread Starter
Found the problem - after changing out the very clean racor filter, and re-bleeding - turned out that it was the transmission not going all the way into forward. I noticed that the propeller shaft turned faster in reverse, than in forward, and the engine sounded / worked better. The transmission shifter pulls back for forward, and although the cable was pulling teh lever back, it was pulling it back and up as well - because of the cable mount / angle.
When I push the transmission lever, with my hand, it clunks into gear and immediately goes faster. I jmoved teh cable mount a little lower, so it pulls more back , than back and up, and it helped some, but I still have to fine tune it. Now, when I shift into forward, it takes a few seconds of revving up, before it clunks, and goes hard into forward. I think I need to play around with the cable adjustments.
At least I know what the problem is, and I learned alot about the fuel system!
yanmar 2GM low cooling water volume?? Northeaster Gear & Maintenance 3 05-31-2007 12:02 AM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 08:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 08:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 08:00 PM
