Old 06-25-2007
Everlong is on a distinguished road
Converting Kenyon Stove to Propane
Anyone did that? It should be basicaly easy, replace the burners, and do the plumbing. Am i right?
Old 06-25-2007
Here .. Pull this
Sailormann will become famous soon enough
Why don't you just save up and buy a propane stove. It needs to be handled carefully !
Old 06-25-2007
Goodnewsboy is on a distinguished road
According to their webpage, you can have your stove converted by TASCO Marine Division
See:
TASCO - Services
Old 06-26-2007
Valiente's Avatar
Yes. Check up the latest regs, though...you can't use flared ends on copper tubing anymore, I think. I started this job, but didn't finish it due to time constraints, but I've seen it finished on a sister boat with an old Kenyon Homestrand stovetop, once fuelled by expensive, cool-burning, flare-prone alcohol.
"Side burners" from barbeque supply shops are 10,000 BTU-rated and work well. Just make sure you have the requisite solenoid shut off and propane sniffer AND CO detector installed...propane requires respect. Also, propane is a pretty damp fuel...consider how you will vent the galley.
Old 06-26-2007
never gave it thought about the propane being damp fuel.. Thanks for all the responses
Old 06-26-2007
Anyone knows what costs are involved?
Old 11-19-2008
jandkellis is on a distinguished road
Flair fittings for propane appliances
Actually ABYC accepts long nut flair fittings for propane; the problem is with short nut flair fittings such as refrigeration fittings which can cause fractures with vibration. ABYC regs. are on line for review.
Old 11-19-2008
Propane Flair Nuts
ABYC accepts long nut flair fittings for propane connections but not short nut flair fittings such as those used in refrigeration applications. These can cause fractures due to vibration leading to leakage.
Old 11-19-2008
erps's Avatar
the pointy end is the bow
I converted the alcohol stoves on two of our previous boats to propane after my dad did his. All we did was pull off the little gas disperser dome thingys and double the amount of air holes by drilling another set of holes and then pull off the alcohol pressure tank and hook up a line to a little coleman camp stove regulator and tank. Worked great. I was young and poor back then, so didn't know anything about ABYC and didn't have the money to buy a propane stove.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Propane or Alcohol Stove? bsfree General Discussion (sailing related) 61 03-08-2010 09:42 PM
Best Value Propane Stove / tank / system geary126 Gear & Maintenance 19 01-03-2008 06:45 PM
How to connect American propane line to European stove faithab General Discussion (sailing related) 3 05-25-2006 04:29 PM
portable propane stove rbtpfe9 Gear & Maintenance 11 11-02-2004 02:58 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
