06-25-2007
The real problem is if the sail slugs or bolt rope aren't the right kind for your boat or if you need other modifications made so the sail will work on your boat. IIRC, a good general rule of thumb is if you have to spend more than 10% of the cost of a new sail on a used one to get it to work on your boat, you're probably better off getting a new sail.
