06-27-2007
Spiderweb cracks or crazing of the gelcoat are usually caused by old age. Stress cracks are usually parallel lines close to the stressed area. In either case, if the cracks are deep enough to penetrate the gelcoat layer, they can let water into the laminate. It is better to seal them than leave them alone, especially if you're not sure how deep they run. That said, it would also be a good idea to find out what caused the cracks, and if it is an on-going problem, to fix it.
