Old 06-27-2007
morrell17 is on a distinguished road
universal diesel impeller shaft
I have a Universal m25xp and the impeller froze, causing the slotted end on the shaft that drives it to break. This is sticking out of the engine and possibly could be the end of the crankshaft, although hard to believe someone would design it like that to break instead of the impeller shaft end, but I can find no diagram showing me what it is attached to. Anyone run into this problem or know anything?
Old 06-27-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Universal Diesel Engine Owners Manual - Sea Water Impeller Replacement - Marine Diesel Direct / Torresen Sailing Site
Old 06-27-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Have you contacted Universal Diesel ?Westerbeke Corporation
S/V Scheherazade
Old 06-27-2007
SENIOR CHIEF
It looks like that shaft has splines and can be pulled out...
Article - Universal Water Pumps - Determine the Pump You Have
Oil pan for Universal Diesel upnatit Gear & Maintenance 7 11-25-2011 12:41 PM
Re-power with universal diesel bayme Gear & Maintenance 3 01-25-2009 10:41 AM
Universal diesel engine problem bcolton Gear & Maintenance 0 04-26-2006 01:50 PM
Universal diesel 5411 rmiille Gear & Maintenance 1 12-30-2001 06:01 AM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
