Old 06-27-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Oxiclean
I have a fabric/carpet headliner on my boat. The PO was a smoker. A friend suggested I try Oxiclean before I rip it out. Has anyone ever used oxiclean and does it really work ?
Thanks,
Paul
S/V Scheherazade
Old 06-27-2007
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
I've used it for several years on a variety of things. It usually works well but is not a miracle cleaner. it does great on carpet stains as one example. I even used it to clean out my bilge, and have used it (diluted) to clean my sails. Give it a try and see what happens. I think it will do well for your problem. I'd buy the granular variety and mix some up in a spray bottle and test it in an inconspicuous spot at first to check for color fastness. If that goes OK, have at it.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 06-27-2007
If you're trying to get rid of the smell... go to a local coffee shop—Starbucks, Seattle's Best Coffee, Peet's, etc—and ask them for 10 lbs. of used coffee grounds. Get two large plastic dishpans and dump the coffee grounds into them.... leave in the boat uncovered for a few days... it will neutralize almost any odor or smell in the boat. And no, it won't smell like coffee after this...once you remove the grounds there won't be any coffee smell either.
Old 06-27-2007
Freesail99's Avatar
I am really trying to get rid of that yellow/tan smoker stain. Febreze worked well on the smell.
S/V Scheherazade
OxiClean ? Saasaan Gear & Maintenance 0 01-28-2007 05:07 PM
