Another Halyard Replacement Question - SailNet Community
Blogs
Old 06-28-2007
SailinJay is on a distinguished road
I know what I need to do to replace internal halyards. Now I'd like to get your opinion as to how to do it. Specifically, does it make any difference which direction one pulls the halyard? Is it better to pull it up through the mast or down through the mast? Thanks.
Old 06-28-2007
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Assumimg there's already shackles on both the old and the new halyards, you'll find you have to pull the old one out through the front of the mast (if a jib halyard -- the main halyard exits at the back of the mast of course) with a messenger line secured to the bitter (ass) end. use duct tape to attach the messenger to the old halyard. I use a piece of tape 9-12 inches long, butt the two ends together on the sticky side of the tape and then roll in up tightly like a cigar. Tug hard to make sure it's secure.
To install the new halyard, attach the ass end to the messenger line at the front of the mast and then pull it (backwards) into place. The shackle will end up on the proper side of the mast and you're ready to go. There also are a ton of threads on this topic.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 06-28-2007
winddancer88 is on a distinguished road
x2. Did just that to replace my main halyard last week. Went with Sta Set X.
Old 06-28-2007
paulk's Avatar
paulk is on a distinguished road
Just in case... you may want to sew the two ends together (sailmaker's needle & palm w/waxed thread) AS WELL as tape them. It would be a shame to have the tape jam in the exit box and strip off just when you thought you'd gotten it through.
Old 06-28-2007
You can also use a lighter messenger line to do this... or you can cut out a section of the core on the old halyard, and then put the outer braid over the new line and whip and cross-stitch it to the new line.... then pull the new line through.
Main Halyard Replacement firehoser75 Gear & Maintenance 10 07-19-2008 06:24 PM
Rigging repair at-sea Lin & Larry Pardey Gear and Maintenance Articles 1 02-16-2008 01:28 PM
Tale of the stuck halyard wlcoxe O'Day 0 08-23-2006 05:45 PM
Another lost halyard... pluscard Gear & Maintenance 13 06-26-2006 06:40 PM
Rereaving the Main Halyard Dan Dickison Racing Articles 0 02-11-2002 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
