06-29-2007
Best Looking Moderator
Hmm, just a thought (or my thought):
Why not put the charger on a 1-2-both switch?
I know you are asking why??? But here is my reasoning: If you have the ability to choose what you want charged, it will give you more control over anchoring. For example: Maybe your engine battery has been setting low for a while and you want to charge it up. By being able to focus all of your power only into the small engine battery, you would charge it faster. The same could be true of the house - where you will use the majority of your juice. Focus it completely there and not bother with the engine.
I personally have my tub wired so I can pull the house bank into the engine or the engine bank into the house. It is an easy wiring job to do and adds another level of redundancy. Depending on how your house bank is wired, you probably have a 1-2-both switch on your house bank (which, in my humble opinion, should not be and should only be on a large parallel). Thus, if you did parallel your house onto one leg of the 1-2-both, you have freed up the other leg for the engine bank. Maybe you could run your solar lead into that and be your own decision maker on what is charged and what is not. Plus, you have another level of redundancy.
Just my initial thoughts.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
