06-29-2007
Best Looking Moderator
Freesail,
THis really is quite a personal opinion. Take the comments (all of them) as such. As a previous (and soon to be again) liveaboard/cruiser, here goes:
LCD is fine for night lights. In fact, I think it is the only way to go for night lighting (red running lights). Outside of that, no thanks. The halogen is a lot "warmer" and gives a better light. Unfortunately, it also draws more power.
I will tell you that we also use regular old lamps. They have a nice spot on our boat where they can plug in. We do have an inverter and can power them off of that. The lamps are actually our preferred means of lighting the boat - believe it or not. The light they give off is just not going to be matched by a 12v light.
We also hard wired in 25w lights that are bulkhead mounted (12v). They are the next best compromise to the lamps. THey draw a lot of power (proportionately), but they have a better light than halogens.
So, to answer your question, a combination of all of them is nice. You can pick and chose which lights you want to turn on based upon the power and needs.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
