06-29-2007
Last Grumpy Old Sailor
Go with Craftsman tools as a minimum... They're relatively inexpensive, easy to replace, have a good warranty on the hand tools, and fairly decent quality.
Going with a cheap set, like you'd get at West Marine is foolish, since you're going to end up buying a good complete set from Craftsman or one of its competitors in the end and will just have wasted the money on the cheap set. Good tools are an investment. Also, stainless steel tools aren't generally worth it. Good chromed high-grade steel tools, if you maintain them are going to be less expensive and last longer.
I heartily second everything SD's written above.
Cheap tools ain't worth it. They are prone to failure when you need them most. Especially on a boat, where you may be, literally, out in the middle of nowhere, where you can't just run to the hardware store to buy a replacement, reliable tools are of the utmost importance.
Jim
