Old 07-01-2007
StillInShock is on a distinguished road
Shim for deck fittings question
I am adding braces to some of the stanchions for the lifeline gates. I have to make a shim to attach the brace to the non-level deck.
I'm not sure what to use - should I use a small piece of teak?
--Not Really Still in Shock http://www.sailnet.com/forums/images/smilies/tongue.gif
Crystal Blue
Old 07-01-2007
Gene T's Avatar
Gene T is on a distinguished road
My first choice would be to use Starboard or it's equivalent from Tap Plastics. Very easy to work with and ignores the weather and sun. Sealing is more difficult with these plastics because nothing sticks to them, but if you use a compression seal method around the bolts you will get a good seal. The method is as follows:
Drill, oversize drill, fill with epoxy, re drill - this process is to seal the core if you have one. To get a compression seal use a countersink on the holes. Then bolt the part but not too tight and when you apply sealant between deck and plastic spacer be sure to use a thin plastic spacer to create a small sepparation between the deck and spacer until the sealant cures. I would use tie-wraps for this as they are perfect. After the sealant has cured pull the tie-wraps out and tighten the bolts. You have just created an o-ring under compression around the bolt. Should be leak free for a long time. Hope I made this clear.
Old 07-01-2007
BTW, when you tighten the bolts, you have to hold the bolt in place and tighten the nut underneath the deck, or you're break the sealant's adhesion to the bolt... creating a leak.
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
Swaging Fittings Tom Wood Gear and Maintenance Articles 0 04-24-2002 08:00 PM
