Old 07-02-2007
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Solar Charger
Anyone have any preferences for solar chargers ? Battery bank is lead-acid, 12vdc, 100 watt panels x2. Interested in your views!
Old 07-02-2007
You're going to need a charge controller with two 100W panels. I would recommend you buy either the BlueSky or the Outback Systems MPPT charge controller for your boat. The BlueSky is less expensive, but not as well built and not as versatile. Both will increase the efficiency of the solar panels by converting the voltage/amperage at which they operate to maximize charging output.
A brief search would have revealed many threads on solar power and charging btw.
Old 07-02-2007
camaraderie's Avatar
moderate?
200 watts of fixed in place panels will give you about 60-70 AMP/Hours per day on average in sunny weather. What are your daily amphour needs? Where do you cruise? Would a wind generator be a better choice. Visit the solar wind threads 900 posts to find the answers to all dilemmas!!
Old 07-02-2007
Cruisingdad's Avatar
Best Looking Moderator
Yes to what SD said. The outback is a better unit and easily expandable but more money. At 200, I would probably buy the Outback -60. That is what I have.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
battery charger for solar and wind SuzieWong Gear & Maintenance 12 09-05-2007 03:00 PM
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 08:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 07:00 PM
