Old 07-02-2007
Swab is on a distinguished road
Barlow 27's - not gripping line
I have a pair of 2 speed self tailing Barlow winches (27's) on our Ericson 36 Cruising Cutter. The winches seem mechanically fine. However, the drums are quite smooth (the once textured area is worn) and they do not grip the line, even when tensioned. I know it is not the line as I have washed the lines and even tried replacements. Is there an easy fix to re-texture the drums so that they will grip the line without damaging the line? Thanks in advance for any help!
Old 07-02-2007
An easy way to re-texture the drums are to either paint them with non-skid... or take them to a machine shop and have the machine shop texture or knurl the surface for you. The non-skid paint is faster, easier and cheaper, but the machine shop work will probably last longer.
Old 07-02-2007
capttb is on a distinguished road
Do they slip if you use 3 or 4 wraps of line on the drum ?
Old 07-02-2007
camaraderie's Avatar
moderate?
They are self tailing...take an extra wrap or two and let the tailer do its' work.
Proper use of the Traveler PDixon Boat Review and Purchase Forum 12 01-02-2008 02:29 AM
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 07:00 PM
Getting Good Starts, Part One Zack Leonard Racing Articles 0 12-18-2003 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
