  #21 (permalink)
Old 07-10-2007
capn_dave's Avatar
Seinor Member
capn_dave is on a distinguished road
Here are the pic's of the various nonskid coatings
I posted this on the orginal thread PArt 2 is there also,
Well I didn't forget the pic's and now I am going to try to post them here. I have been cruising and this is my first attempt on this site. I might need someone's help.
This is the Duraback coating. This was applied 3 months ago and is white (there is nothing wrong with my camera) Like I said it attracts dirt. The boat has been in the yard for a refit.
This is another shot of the Durabak. The edges are coming up. I don't know if it was applied correctly or not. I do know the owner used the special primer. This product is great at hiding imperfections.
This is Awl grip with sand. The owner said it was allot of work, as the surface has to be prepped to hide imperfections and requires 2 coats. I also have heard the paint will wear and then you have the sand showing.
This is a shot of the Kiwi stuff. Owner was very happy with ease of application and the results. It is also good at hiding imperfections.
Here is another shot of the Kiwi grip
It kinda looks like rolled gel coat and has a nice feel. How long it will hold up is another question. I contacted them and I was told about 3 years in heavy traffic areas.
The last pic will be of the Interdeck. seems it wont come through on this post. look for part 2
Fair Winds
Cap'n Dave
  #22 (permalink)
Old 07-10-2007
Hyperion's Avatar
Scourge of Howe Sound
Hyperion is on a distinguished road
Thanks for the pics. I will now be trying the Kiwi Grip on the Harpy.
  #23 (permalink)
Old 07-10-2007
capn_dave's Avatar
Seinor Member
PART 2 pic's of the various nonskid coatings
Here is the interdeck. It dosen't cover blemishes in the deck well. It has a good feel, seems to good underfoot. I haven't tried it while wet.
I hope this helps. So far I am impressed with the Kiwi Grip product.
The ease of applying was most impressive, followed by the look and feel of the product. Durability is still the question.
Fair Winds
Cap'n dave
  #24 (permalink)
Old 07-10-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Thanks very much capn dave. I been looking forward to your pictures and report.
Paul
S/V Scheherazade
  #25 (permalink)
Old 06-22-2009
mattstamour's Avatar
mattstamour is on a distinguished road
Kiwi Grip update?
I'm considering the Kiwi Grip product for my '76 Catalina. Are there opinions of durability now that this thread is 2 years old?
MattStAmour
Noank, CT
Catalina 30
Hull #222
  #26 (permalink)
Old 03-01-2010
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Kiwi Grip
I used Kiwi on my core-rot-repaired Alberg 35 last spring, sailed all summer and fall, giving the stuff a pretty good workout. The first thing I can say about it is that you are NOT going to slip around with this under foot. Being a single-hander, that was my #1 criteria. It is certainly not as pretty as a finely tailored job using Awlgrip and shaken-on aggregate but if staying on deck is important to you, it is infinitely better than any textured resin surface I have ever seen. Painting it on is very easy and quick, requiring just brush and roller. It IS tough on the knees if you need to crawl along on it but I applied it with a double roll which really gives it a rough surface. As far as durability goes, it seems to be tough as nails, taking any number of anchor abrasions. We'll see how it holds up over a number of seasons. Have done some patching and the Kiwi blends in quite well (white). I will likely knock down the roughness a bit and give it another slightly less rough coat this spring. It seems to overcoat well although I don't know how it overcoats after a year of service. If you are applying it, make sure you remove masking tape while it is sticky. The tape will pull up the edge if you let it dry completely. It is also a pain to get off woodwork should you splatter it around. So wipe off any splatter before dry.
Kiwi prop --- feathering Johansail Gear & Maintenance 27 03-13-2010 07:49 PM
non skid deck paint freddy4888 Gear & Maintenance 10 01-18-2007 01:39 PM
Restoring non skid decks Petar Gear & Maintenance 9 06-13-2006 04:23 PM
Need advice on non skid paint HeartofGold Gear & Maintenance 5 04-13-2004 06:44 AM
Getting a Grip Don Casey Gear and Maintenance Articles 0 04-11-2004 08:00 PM
