To quickly spot your boat - SailNet Community
post #1 of 11 Old 07-05-2007 Thread Starter
Is there such a thing to attach to the very top of your mast, ( a colorful something) that won't get caught up in the lines....to quickly see your moored boat from land?
Debz is offline
post #2 of 11 Old 07-05-2007
Señor Member
TrueBlue's Avatar
A burgee can be mounted on a pigstick at the masthead and hoisted up by a dedicated flag halyard. We frequently fly a small Yacht Ensign from our mizzen - however, due to the ketch rig, our boat is easily identified in a mooring field anyway.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #3 of 11 Old 07-05-2007 Thread Starter
Thanks for your suggestion...much appreciated!
Debz is offline
post #4 of 11 Old 07-05-2007
One thing I've do with my boat is added some retro-reflective tape to the mast. This makes identifying it at night much easier. My boat tends to stand out since it is a multihull...
sailingdog is offline
post #5 of 11 Old 07-05-2007
Debz,
My son bought a hughe Pirates flag in the Caribbean once. There is no way I will sail with that because its illegal, but while moored, and we are in Pirate treasure hunt mode, I rig an old fishing rod to a halyard as shown in the drawing, leaving at least 2 feet between the 2 knots. I then get a second line to keep the rod's butt down, (and to bring it down later) and pull the halyard as tight as possible.
The flag is attached to the pole. Simple, and easy. The pole is not exactly vertical, but does the job pretty easy. If you have questions ask.
I also use this method to fish Halyards that went up the mast, using my hook stick (I don't know the name for it in English), I hoist the hook, and once near the halyard I roll it around and pull down...a lot of trial and error, but works, doesn't it Val?? (G)
Giulietta is offline
post #6 of 11 Old 07-05-2007 Thread Starter
Love it...excellent idea!
Thank you so much.
Debz is offline
post #7 of 11 Old 07-05-2007
pigslo's Avatar
Perhaps a spray of yellow paint at the masthead.
Pigslo
pigslo is offline
post #8 of 11 Old 07-05-2007
Owner, Green Bay Packers
A sign on the transom stating, "Free Beer-Help Yourself". You will then be able to just follow the crowd at any hour of the day or night. You may even find that you no longer need the expense of your own dingy, what with the "launch service" to your boat. (g)
Wm. F. Buckley, Jr.
sailaway21 is offline
post #9 of 11 Old 07-06-2007
humble pie rat
CapnHand's Avatar
You could also set it on fire. Easier to find. Smaller line up. Same result.
CapnHand is offline
post #10 of 11 Old 07-06-2007
Reflective tape works well!
I put a 2" wide band of yellow reflective tape on the top of my mast. its easy to spot and very easy at night with flashlight or reflected from anchor light.
S/V Que Pasa?
capnjim02 is offline
Making Passage w/o a Rudder wind_magic Seamanship & Navigation 60 07-16-2010 01:23 PM
Small Boat Cruising David Schaefer Cruising Articles 0 06-09-2004 08:00 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
How to Choose the Right Boat Don Casey Cruising Articles 0 04-20-1999 08:00 PM
