My first haul-out... - Page 3 - SailNet Community
post #21 of 39 Old 07-09-2007 Thread Starter
Sailingdog,
How long did it take you to prep your hulls? Sounds like you've got some very accomodating folks there at the yard...
I'm not so lazy as I am plain flabby... my hooves are swollen from not getting enough exercise, and my curly tail is as thick as keilbassa. Sitting at the desk, day in and day out, is really painful.
sailhog is offline
post #22 of 39 Old 07-09-2007
Sailhog-
The guys at my marina rock... very helpful and very accommodating to the slip tenants.. Prepping wasn't too bad, since I had the hulls sodablasted, and that did the majority of the prep work.
Since then, I have gone back and repaired a few dings, scratches and voids that I found. I've also done some fiberglass work as well. Now, I've just got two more places to fiberglass, weather permitting, and then this week I hope to barrier coat and paint. I've got one crew member volunteering to help over the weekend, and I hope to have everything prepped by Thursday.
I also just finished putting the anti-skid paint on the new bridgedeck I glassed in earlier this year.
Originally Posted by sailhog
Sailingdog,
sailingdog is offline
post #23 of 39 Old 07-09-2007
Señor Member
TrueBlue's Avatar
I decided 4 seasons ago, after buying my current boat, that someone else was going to strip years of paint off the hull and apply a barrier coat. Even though I'm self-employed and can take any amount of time off, my weekends are still priceless.
What many boat owners in similar situations as me, don't factor into the DIY or hire a Pro equation, is the income lost by DIY. It would have been more expensive for me to spend 40 hours of lost wages doing this work than to hire it out.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #24 of 39 Old 07-09-2007 Thread Starter
TB,
I'm self employed as well and face the same dilemma. I'm also wary of screwing it up, as this will be my first experience in getting the bottom painted. That Nauticat of yours would seem to have a lot of bottom to paint for a 33 foot boat. You've got to have a couple of acres of hull under you...
sailhog is offline
post #25 of 39 Old 07-09-2007
As I too am self-employed for the most part, I did take into account the money I could make versus what it would cost me to have it done by a yard. That's why I had the boat sodablasted. Sanding or stripping the old paint off wasn't economical IMHO.
However, doing the rest of the work, while it might have been better to farm it out, was something I wanted to do myself. I plan on taking my boat to places where boatyards are a bit scarce and I wanted to make sure that the bottom was prepped properly. The work I've done during the prepping of the boat for the barrier coating and bottom painting has been stuff that wasn't technically necessary but I wanted to do it. I added some glass to the area around the centerboard trunk to beef it up—was it necessary, probably not... will it give me some peace of mind that I've done it...definitely.
I've re-built or modified almost every system on this boat, and if I have a problem out at sea... I am probably the best-qualified person to fix it—since a lot of the stuff was my handiwork to begin with.
post #26 of 39 Old 07-09-2007
Señor Member
TrueBlue's Avatar
You're right - for a 33, there's a lot of underwater area displacing an 18,000 lb boat. That was the main reason for hiring the job out. Other factors for this decision included additional post survey money, which was obtained through a selling price renegotiation with the sellers, and my desire to have the best possible professional job done. In theory, this will increase resale values as well.
Here're some pre-suvey photos showing the nasty job ahead:
The following shot is from of the yard's paint shop, where the bottom was stripped with Peel-Away III, hull was ground, faired and then Interprotect 3000 was sprayed on. This was all done over the course of the winter after a November purchase, in a heated shed with a radiant heated slab.
I applied the final bottom paint coats after she was hauled back outside in early Spring - ready for launching.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #27 of 39 Old 07-09-2007 Thread Starter
TB,
Unbelievable... Looks like a lot of work and a lot of money. But it looks fantastic... I have to say that I absolutely love the Nauticat. Nice job...
sailhog is offline
post #28 of 39 Old 07-09-2007
christyleigh's Avatar
Sailhog... you can't fool me - I met you - your younger and in good shape. Blisters may or may not come. I took 2 vaca days last October to do a short haul, light sand with a random orbital hooked up to a vacuum, slept on the boat, and put on one coat of ablative. Yup, my arms hurt like hell.... but not $1,000.00 worth of hell - Do It
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #29 of 39 Old 07-09-2007 Thread Starter
Hey Stan,
Good to hear from you, and thanks for the advice. The problem is finding a yard that will let me do it myself. If I can find one, I definitely will. One question for you: Did you have to wear a suit during your prep work, or was the orbital with the vacuum sufficient?
sailhog is offline
post #30 of 39 Old 07-09-2007
RAGTIMEDON's Avatar
Another thing to factor in to the cost equation--- Ben Franklin said "A penny saved is a penny earned" but that was so long ago that they had virtually no taxes. Saving that thousand bucks is as good as earning 1600 in today's economy!
RAGTIMEDON is offline
Haul out in Gulf Shores Alabama? j34035 Gear & Maintenance 8 11-30-2006 09:53 PM
Best Haul Out in Caribbean for Paint/Refurb kaakre Gear & Maintenance 2 10-19-2006 09:50 AM
It's no breeze to haul sailboat off beach - Asbury Park Press NewsReader News Feeds 0 09-22-2006 04:15 AM
It's no breeze to haul sailboat off beach - Asbury Park Press NewsReader News Feeds 0 09-06-2006 05:16 AM
Cat haul out in W. Florida dsprygada Gear & Maintenance 0 05-15-2004 05:45 AM
