07-08-2007
Actually, if the boat is tiller steered normally, and the regular tiller is the one the vane is controlling, the lines should cross. However, on several boats, both tiller and wheel-steered, I've seem a small auxilliary tiller setup for the wind vane to control the rudder and in some cases the auxilliary tiller points aft, not forward, and the vane lines do not cross. This allows the main tiller to be tipped up and out of the cockpit, when sailing under windvane control.
