self tailing winches but what size - SailNet Community
Blogs
Old 07-09-2007
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
I am looking to replace my main winches the ones for the jib sheets this fall. I was looking at self tailing as they seem easier when sailing single handed. My question is how do I determine the size winch to buy. I have a catalina 27 with Lewmar 10's single speed. I think the 10's are small is 16 appropriate for this vessel? Another question is, is it worth getting two speed winches? Thanks in advance!
Old 07-09-2007
BarryL's Avatar
BarryL is on a distinguished road
Hello,
If you will be sailing shorthanded, Self Tailing winches are definitely the way to go. If your crew is not very strong, 2 speed winches are also very nice. My Newport 28 came with Lewmar 30ST, 2 speed, self tailing, which worked great on that size boat.
Good luck,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 07-09-2007
The Lewmar 30ST's would be an excellent choice, but may be a bit pricey for you.
Old 07-10-2007
saurav16's Avatar
True, I want to try to keep the costs to a minimum, the 30st's are expensive, any other's you all would suggest?
Old 07-10-2007
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
There are some things you should buy on the basis of quality and nowt else.
Old 07-10-2007
The fuzzy one's right in this case... skimping on winches is generally a false economy.
Old 07-10-2007
Jotun's Avatar
Space cadet
Jotun is on a distinguished road
What about simply putting those self-tailing conversion rings over the top of the old winches? I don't think you need two speed winches for the jib sheets.
Old 07-10-2007
I'd go with a 16ST one-speed lewmar. Going from a 10 to a 16 is a reasonable leap in size...going all the way up to a 30 is a bit overkill.
BTW, you can always use Lewmar's winch sizing calculator to figure out if the 16St will work for you.
Old 07-10-2007
pigslo's Avatar
pigslo is on a distinguished road
Used winches are another consideration as winches that are maintained have a long service life.
pigslo
Old 07-10-2007
saurav16's Avatar
Barient winches?
As far as used winches Barient seems to be cheaper on ebay. How are Barient winches compared to Lewmar and Harken?
winch size maestro Gear & Maintenance 6 12-19-2002 09:09 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
