Blogs
User Name
Old 07-09-2007
chuckg5's Avatar
chuckg5 chuckg5 is offline
chuckg5 is on a distinguished road
vhf / gps interference
just installed a Garmin 3206 in the nav station
already have a Icom 502
the minute I turn on the Garmin, channel 28 on the vhf comes on with static an stops the scan
i know they're right next to each other but the garmin shoulddn't be putting out radio waves.
does any one know what's up with this?
all power wires meet up in the same ground an positive bus bars
i cancelled out channel 28 on the scan but that doesn't help
thanks!
Old 07-09-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
How do you have the antenna coax cable run for the VHF?
BTW, the FCC statement on the equipment probably says that it is allowed to give off some radio wave interference.
If you're new to the Sailnet Forums... please read this POST.
Old 07-09-2007
chuckg5's Avatar
Saildoggy
straight shot coax into vhf, nothing fancy
r u suggesting maybe more grounding of said coax, close to the box?
this is in recieving mode, I'm not even transmitting
Old 07-09-2007
knotaloud's Avatar
knotaloud knotaloud is offline
Re Member
knotaloud is on a distinguished road
I remember reading somewhere that if your GPS antenna cable runs too close to the VHS coax, that could do it, or if your GPS antenna cable has a big loop or coil, it can act like a radio antenna and amplify radio interference. And I would ground the coax
Old 07-09-2007
SEMIJim's Avatar
SEMIJim SEMIJim is online now
Nautical Newbie
SEMIJim will become famous soon enough
Just tighten-down the squelch on the VHF rig a bit. All electronics generate RF noise. All. You can pick up some ferrite donuts at certain electonics supply places or Ham Radio swap-and-shops, loop your radio and GPS power through those a few times and reduce somewhat any RF noise that's leaving/entering through the power leads. (That'll also somewhat reduce engine alternator noise in the radio.) That may help some. Other than that: Just make sure your grounding is good, and your coax in good shape and well-terminated at both ends. That's about all you can do.
Jim
Old 07-09-2007
SEMIJim's Avatar
Nautical Newbie
Well... close. The GPS might emit some amount of "random" RF noise, across the spectrum, from its receiving antenna system. All radios, even pre-digital ones, do. (Tho the pre-digial ones weren't random. You could tell what station they were tuned to by what they were radiating.) Shouldn't be much, though. All a loop in the GPS' antenna line will do is perhaps radiate more noise in in the area of the loop.
It'll already be grounded via the chassis of the radio--and possibly at the antenna end, as well. (Depends on the antenna type and mounting method.)
Jim
Old 07-09-2007
I would run the VHF coax antenna cable as far from the GPS cabling as possible and add ferrite cores to the cable. Both should help reduce any interference caused by the GPS.
Old 07-09-2007
chuckg5's Avatar
I do have numerous loops in the gps cable
i'll try a move the coax an gps cables furthur apart , tommorow
thinking of wrapping aluminum foil around the power inputs of both as
a test to see if that can eliminate the noise
thank you for replies!
Old 07-09-2007
SEMIJim's Avatar
Nautical Newbie
It's best to avoid loops in antenna cable, even if it's just a receiver cable, if you can. You certainly don't want a bunch of looped GPS antenna cable right near the VHF radio.
That would be best. The shield on antenna cable is imperfect.
My guess is all that'll accomplish is looking messy and create a fire hazard.
You're welcome
Jim
Old 07-09-2007
chuckg5's Avatar
I know , Jim
the aluminum would just be a test shield for r/f
absolutly no good near buzz bars
Display Modes
vB code is On
FYI: GPS interference from TV antennas gstraub Gear & Maintenance 0 01-10-2003 08:36 AM
Handheld GPS Overview Tom Wood Seamanship Articles 0 05-31-2001 08:00 PM
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
