Old 07-09-2007
Windermere's Avatar
New Sailors Jane & Bernd
Windermere is on a distinguished road
Centerboard Problems!
Hi, I just bought a Morgan 454 w/centerboard. When moving it to the work area from dry storage, the centerboard dropped, although the line that is suppose to hold it up was tight. I think I will have to find out what's happening by opening the pully case, but I can't get it open. Anyone have any ideas or experience with this? Thanks in advance, Bernd
Old 07-09-2007
Probably should contact the Morgan owner's association. They can probably tell you what's going on with the centerboard housing.
Old 07-10-2007
Windermere's Avatar
Thanks Sailingdog! I've Googled a Morgan Owner's Association, but came up empty. Do you, or anyone, happen to know the website?! Thanks! Jane
Old 07-10-2007
knotaloud's Avatar
Re Member
knotaloud is on a distinguished road
Here's a few Morgan links that might help
Morgan Links
Old 07-10-2007
Windermere's Avatar
Great! Thanks Knotaloud. Jane
Old 07-13-2007
Windermere's Avatar
This is interesting, here is what we received back from Charley Morgan...
Sorry Bernd, I do not have information on the model that you have.
It sounds like opening the pulley case will be part of the solution
Cheers and smooth sailing, ~ Charley Morgan
Old 07-17-2007
MikeGC is on a distinguished road
Windermere,
I have a Morgan 454 as well and replaced the center board pennant the last time it was out. The guys in the yard cut in to the glass as the top of the centerboard housing replaced the line and re-glassed it. I did not see them do did but they acted like it was not a real tough job.
I would also recommend that you consider replacing the centerboard pennant housing that runs through the cabin. Mine had corroded and was leaking. I had to replace it in the water. This was a little tricky but we got her done. Out of the water is should be easy.
Mikegc
Morgan 22 Centerboard + Swing Keel Restoration briceburg Gear & Maintenance 4 09-23-2007 05:51 PM
Steel centerboard zinc Wayne25 Gear & Maintenance 8 01-15-2007 03:18 AM
Securing centerboard when trucking a vessel roger_mexico General Discussion (sailing related) 2 10-20-2005 06:35 AM
Centerboards and Swing Keels Bruce Caldwell Buying a Boat Articles 0 05-04-2004 08:00 PM
Centerboard Tradeoffs Mark Matthews Learning to Sail Articles 0 12-02-2001 07:00 PM
