Old 07-10-2007
StoutHeart is on a distinguished road
Lugging at medium RPMs
My Yanmar 15hp is lugging when I go above 2000 rpms (guessing because the tack doesn't work). At any rate, when I'm in gear I can make barely 3 knots before the oil and smoke start coming out. Checked the intake and checked the fuel filter. All seems fine. One thing that occurred to me was, my new oil filter is a bit smaller then the old. I was assuming the one I bought with the engine model number was the right one. Any insight?
Old 07-10-2007
Hotpuppy is on a distinguished road
Looked at your prop for fouling lately? Doesn't take much to make your prop not work with a hoot.
Hotpuppy Too, Tartan 27 - Hull #71 - 1964
Houston, Texas (Kemah)
Old 07-10-2007
Ya, the prop isn't great. But it still does it even when I'm not in gear.
Old 07-10-2007
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
I would check your compression first and then the injectors. It sounds like it isn't burning efficiently and those are two likely culprits.
Which Yanmar model is it? If it's the 2QM15, I have the operation and the service manuals on my website, if you'll find them useful.
Here's the link (Yanmar stuff is half way down): literature
-Jason
Old 07-10-2007
The other problem could be the valves on the engine may need adjusting.
Old 07-10-2007
knotaloud's Avatar
Re Member
knotaloud is on a distinguished road
Too much oil?
Old 07-11-2007
jrd22's Avatar
Courtney the Dancer
How did this begin? Was it gradual or all of a sudden? You say "then the oil and smoke start coming out", what color smoke and what is the oil coming out of? What is the water temp. doing when this happens.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 07-11-2007
RichH's Avatar
RichH will become famous soon enough
Your symptoms are probably closer to a blocked exhaust system than anything else. Yanmars that continually burn contaminated fuel ('cloudy' fuel that doesnt burn well in the combustion chambers) will usually wind up with a LOT of soot or coke deposits in the exhaust system ... usually deposited near the water injection elbow. Such deposits will 'narrow' the gas passages and cause high backpressure of the combustion chamber which will lead to reduced rpm and power output ... the smoke and 'oil' (probably soot deposits breaking loose) at higher rpm are the typical clues.
If you have the 'stock' Yanmar cast iron exhaust 'drop' that is fairly easy to unbolt and examine for blockage. However if your engine has been retrofitted with a 'dry stack riser' made of black iron pipe .... you typically have to break the pipe apart to find out if its blocked. If you have the 'typical' clabbered together 'dry riser stack', Yanmar dealers now offer a water injection elbow thats made of aluminum thats easier to remove from 'pipe' than the cast iron one they 'used' to offer.
Old 07-11-2007
Thanks for all your feedback folks. Some great comments. Going to take a look at the exhaust tomorrow. I'll let you know how it goes.
Old 07-11-2007
Cruisingdad's Avatar
Best Looking Moderator
SH,
The backpressure is easy to check. You can go buy a standard pressure gauge from the autoparts store, with a max pressure of 15psi or so. These usually also have a vacuum side too - but you obviously will not need that. Next, find put a needle adapter on the end of the hose and insert it into the exhaust, right after the mixer elbow, with the needle pointing aft. You should be reading about 2.8 psi with about 3 max (I assume this would be the case on your engine, it is on the 4jh4e). This is taken at WOT (Wide open throttle). Fill the hole when done with High Temp Silicone.
If your pressure exceeds 2.8 -3 psi, you may have more problems than just the exhaust. The excessive pressure causes the cylinders to overheat, and over time will scar them - permanently. THis causes compression failures and many of the symptoms you have. Unfortunately, there is no fix for this short of a rebuild or replace. To check whether your engine is ok, you can compression check the cylinders. Many of the modern diesels are in the mid 500 psi's as I recall. However, the differential may be the most important thing between the cylinders. 10% is typically considered the max.
As far as a high back pressure, this can be cause be a blockage, too small of an exhaust hose, muffeler, riser... or anything else from here to there.
Did that make sense?
I am NOT a diesel machanic. However, this information comes directly from Bob at Mastry Yanmar (Distributor), number: 727-522-9471. I hope that helps. Please verify my information with him as you feel appropriate.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
White Smoke from Older Diesel at Higher RPMs kcoffey Gear & Maintenance 3 06-24-2004 03:23 PM
RPM''s on Perkin''s 4-108 ABullard Gear & Maintenance 0 11-03-2002 03:49 PM
