Old 07-10-2007
Valiente's Avatar
A better V-belt?
Having just thrown a V-belt from my PTO/cooling pump pulley/alternator for the first time (see "Overheating situation" thread), and having been caught without a spare, I am soliciting opinions for manufacturers of good, after-market V-belts. The size is not extreme: 1/2" by 44" or 45" inches. I have just the one stock 55 amp alternator, which will go to a 100 amp Balmar before we leave.
Nigel Calder seems to advocate for Gates Green Stripe V-belts as being reliable. I can get them from an auto place for $15.07 each. Thoughts? Arguments? Some magical, never-shred belt maker I might not have heard of? (Likely!)
Old 07-11-2007
RichH's Avatar
RichH will become famous soon enough
Vee belts made of spectra (various manufacturers) seem to last better than 'standard' (balata) vee belts.
Also consider that vee belts wear out prematurely in marine applications because the belt sheeves become roughened due to constant rusting of the polished groove faces..... a bit of 320 sandpaper held in a vise grip (so you dont get your hand torn off when holding the sand paper) and carefully inserted INTO the grooves to 'smooth' out all the rust pits - does 'wonders' in extending the life of the vee belts. :-)
Old 07-11-2007
Also, you should make sure that the v-belts your getting have the same v-profile as the pulleys on the engine. If the two profiles are different, the belts will wear amazingingly quickly.
Old 07-11-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
The v-belts made for riding mowers are extremely tough...
Old 07-11-2007
camaraderie's Avatar
moderate?
Gates is great.
Helmets and sailing Ilikeboatin General Discussion (sailing related) 120 06-02-2011 07:14 PM
NAVICO CORUS WP300CX BELT Seagypsywoman Gear & Maintenance 3 03-05-2009 06:32 PM
Balmar Alternator Eating Belts sjacovino Gear & Maintenance 13 06-17-2004 04:59 PM
Changing belt on Catalina 30 lgsailor19 Gear & Maintenance 2 05-23-2003 02:00 PM
Autopilot Overview Tom Wood Gear and Maintenance Articles 0 03-22-2002 07:00 PM
