11-19-2008
For what it is worth, I applied KiwiGrip to my decks last fall. I've documented the process here (prep and prime) and here (final application).
The KiwiGrip material is uniform in color, so I'm not sure which of the non-skids pictured earlier in this thread CapnBlu is referring to. On the other hand, one does need to take care with the KiwiGrip to ensure uniform texture and coverage (and the close up pictures shown above do look pretty bad in those regards).
Here's one relatively close up picture of the finished job on my boat (this is shortly after launch and the boat hadn't been washed yet, so ignore the dirt):
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , from the Chesapeake to Newfoundland
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , a new voice for ocean conservation
Reason: update URLs for links and image
