Old 07-11-2007
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
electric motor for dingy
I have a small 8' dingy (rigid) and was getting tired of rowing it against the current to get out the mooring. I was thinking of using an electric small motor on the dingy. I dont have any experience with the electric motors but was wondering if anyone used them on their dingys. Also what kind of batteries does it take and how long does it last?
Old 07-11-2007
Saurav-
Again...if you had done a search, you would have seen that there was a recent thread on this. You can read it here
Old 07-11-2007
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Check these out, they seem to have built a great product,
torqeedo: Home
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 07-11-2007
saurav16's Avatar
Thanks SD, read through the previous posts says you can use the deep cycle marine matteries but those are heavy and expensive. It doesnt' really say if there is an alternative smaller battery to use and how long it would last?
Old 07-11-2007
The problem with the smaller, non-deep cycle batteries, is that they're really not designed for that kind of use and will fail more quickly than a deep cycle battery would. Also, they may not have as much capacity... which results in a shorter run time. Personally, I'd stay away from an electric trolling motor, since most of the motors aren't all that corrosion resistant, and the combined weight of the motor and batteries will often outweigh that of a small four-stroke or two-stroke gasoline powered outboard, even with an external fuel tank.
Electric Motors and Sailing Vessels Mark Matthews Gear and Maintenance Articles 0 11-17-2002 07:00 PM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 08:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 07:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 07:00 PM
