Aging Rigging - Page 2 - SailNet Community
post #11 of 16 Old 07-13-2007
"I think it's much more likely that the rest of the boat is moving, ...the tangs on the mast are working downward."
Good thinking! That could really ruin a day.
hellosailor is offline
post #12 of 16 Old 07-18-2007 Thread Starter
tagster's Avatar
My turnbuckles are of this design (particularly the left picture):
But considerably more solid. They have rather solid chromed bronze knees on either end (similar to the one on the bottom of that figure), and the two-way threaded screw in the center is 3/4" stainless.
tagster is offline
post #13 of 16 Old 07-18-2007 Thread Starter
tagster's Avatar
The cables are black coated something or other, which looks to be copper but I'm really not sure. Definitely not stainless steel, and definitely look nothing like the ones I see on any other vessels.
tagster is offline
post #14 of 16 Old 07-18-2007
Tagster-
I can a problem with your rigging...and something you should correct when you replace it. The turnbuckles should have toggles at the outermost ends, where they attach to the boat. If you don't have toggles at the bottom of the shrouds and stays, the wire and turnbuckles can fatigue a lot more as they can't move in one axis.
sailingdog is offline
post #15 of 16 Old 07-18-2007
Courtney the Dancer
jrd22's Avatar
You might check this link to Brion Toss Rigging in Pt. Townsend (SparTalk - Powered by vBulletin ) you can post your question there and get some feedback from riggers. Seems like you have figured out a good temporary solution by cutting the ends of the bolts off, but if those bolts are good you might end up having to buy new ones next year if you can find them.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #16 of 16 Old 07-18-2007
If your rigging is wire rope looped over the end of the turnbuckle as shown, you can undo the rope, slack off the turnbuckle then reclip the rope at the new position. See Crosby Wire Rope Clips - Warnings and Safe Installation Instructions for instructions.
Cheers,
Tim
Gramp34 is offline
Standing Rigging Too Old? StillInShock Gear & Maintenance 79 11-23-2011 12:18 PM
Rigging repair at-sea Lin & Larry Pardey Gear and Maintenance Articles 1 02-16-2008 12:28 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 08:00 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 07:00 PM
Standing Rigging Storage Jerry Hammill Gear and Maintenance Articles 0 10-15-2001 08:00 PM
