Old 07-12-2007
groundhog is on a distinguished road
Holding Tank: how to get a 4" hole threaded - FPT
I am ordering a high density polyethylene (HDPE) holding tank made.
I want to put a 4" hole at the top so I can use it as a clean-out port. Something I can put a stick in and poke around. I will use one of those standard pvc plugs as a hatch (same thing that is in your sewer line clean out that the roto rooter guy uses).
The maker can thread all the holes except that one. He doesn't have the tap and can't afford it for only one job.
Any ideas on who might be able to do this type of thing?
I sent out a few emails to plumbers, but without success so far.
thanks,
gh
Old 07-12-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Many winery tanks, have an 8 inch handhold. Which is a 8 inch lid that screws into place. Maybe add wine tank to your search to pull up a few more companys.
S/V Scheherazade
Old 07-12-2007
Umm.. why don't you find a deck inspection plate that you think will do the job, and have the tank maker leave a hole the size required by the deck inspection plate. Then you can attach the deck inspection plate deck ring to the tank and use the deck plate as the inspection hatch. I am using a clear Beckson 6" circular screw-in deck plate for the inspection hatch on my holding tank. The reason I went with a clear deck plate is so I can do a visual inspection as necessary, and only open the inspection hatch if absolutely necessary.
Old 07-12-2007
camaraderie's Avatar
moderate?
Mayb something like this instead?
West Marine: Locking Deck Plates Product Display
Old 07-12-2007
I used this instead... I think it seals better than the locking type ones do.
Old 07-12-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
Go to your plumbing supply house and get a 4" bolt up flange made of PVC. It'll gasket inside and out, and the plug screws in. Cheap.
Wm. F. Buckley, Jr.
Old 07-12-2007
6string's Avatar
6string is on a distinguished road
This seems like a good way to go. However, should for some reason you still need to machine the threads, there is a way to have that done without using a tap. You would have to take the part to a machine shop where they can thread mill on a CNC machine. I make a living helping people with threading many different materials. Should you want to pursue this route and would like more info, PM me and I will help you out.
Old 07-13-2007
chuck711 is on a distinguished road
Have a cover plate made of same material 3/4 inch larger than the opening. Then tap the tank with 10-24 screws and using a fuel resistant gasket of the same size ( neoprene )put it all together with washers and lock washers/ screws. Works great
Holding tank location stoutwench Gear & Maintenance 17 04-11-2007 02:40 PM
Custom Holding Tank Mithril Gear & Maintenance 6 03-15-2007 03:48 PM
Holding Tank Questions John_colpitts Gear & Maintenance 14 08-31-2006 06:42 PM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising & Liveaboard Forum 0 02-28-2005 09:34 AM
Holding Tanks Tom Wood Gear and Maintenance Articles 0 06-10-1999 08:00 PM
