Old 07-12-2007
Windermere's Avatar
New Sailors Jane & Bernd
Windermere is on a distinguished road
Rust on Gel Coat
Is it possible to completey get rid of rust on gel coat? I sure hope so! Thanks, Jane
Old 07-12-2007
depends on if the rust is on the surface, or in the gelcoat. If the gelcoat is old and porous, it is very possible that the rust has gotten in the pores in the surface. I would try using a Mr. Clean Magic eraser... they're pretty effective for fixing this type of problem, even on fairly porous surfaces.
Old 07-12-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
might also try "Lime Away"
Product Review: Lime-Away - Associated Content
Old 07-12-2007
Maine Sail's Avatar
Yes..
Any of the acid based products like FSR, YSR or On & Off will work. I prefer On & Off and apply it with a cheap chip brush. You'll be amazed how quickly it eats the rust...
______
-Maine Sail / CS-36T
Old 07-12-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
If Soft Scrub doesn't do it, try oxalic acid. You can find it at the hardware in crystal form. Make up a paste mixture and let it sit on the rust a bit. Scrub with a Scotch pad. You can find the oxalic acid as a liquid in many deck cleaning treatments.
Wm. F. Buckley, Jr.
Old 07-12-2007
hellosailor's Avatar
On gelcoat, sure. IN gelcoat...oxalic acid (in the supermarket as "Baternder's Friend" or "Oxo" etc.) and patience.
Once it is out--wax the gelcoat. Wax seals the pores and prevents further staining and degradation of the gelcoat.
Old 07-13-2007
Windermere's Avatar
Thanks everyone, I proclaimed it to be hopeless too soon!
Old 07-13-2007
Hyperion's Avatar
Scourge of Howe Sound
Hyperion is on a distinguished road
Had the same issue and SD's suggestion of the magic eraser worked, er... like magic.
Old 07-13-2007
And that's why they're called that...
gel coat dm567 Gear & Maintenance 15 01-02-2007 11:55 AM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 07:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 07:00 PM
Gel coat cracks seac Gear & Maintenance 3 12-13-2002 05:46 PM
Gel coat vs epoxy for hull dpoperngr Gear & Maintenance 6 10-28-2002 11:48 PM
