Blogs
User Name
Old 05-20-2002
thibaut thibaut is offline
thibaut is on a distinguished road
Recoating rusty fuel tank
My diesel tank is not accessible being part of the keel, rusty after 20 years of neglect, what paint/epoxy/? can be use to seal the old rust in place and form a lining?
Old 05-20-2002
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enough
I am not sure if you are talking about the outside or inside of the tank. On the outside of the tank you can wire brush and vacuum up all of the loose rust, treat with Ospho to consolodate the remaining rust, paint with a zinc rich epoxy primer and then over coat that with a coal tar epoxy. Unfortunately, most steel tanks rust out from the inside and there really is nothing that you can do about that except cut out the tanks and replace them once they rust through.
Old 05-20-2002
windship windship is offline
windship has a little shameless behaviour in the past
Hey Jeff, you''ll love this one,
I know of a guy who had (or has)a leaky diesel tank.
He took all kinds of 5200 and encapsulatsd his entire fuel tank that is located in the bildge.He filled his entire bildge with 5200!!! ''cause his tank leaked!!!
How do you think He''d do in weeds and mud???
Dennis
Sponsored Ad
Old 05-20-2002
Jeff_H's Avatar
Super Moderator
Do you have any idea how that worked? Did it cure the leaks? If it did cure the leaks I wonder if he still had problems with a lot of debris clogging his filters.
Display Modes
vB code is On
Fuel tank problems Lusk Gear & Maintenance 18 01-23-2007 06:17 PM
Sabre 28 Fuel Tank RickFagan Gear & Maintenance 1 10-26-2006 03:08 PM
Holding or fuel tank jeanneau beneteau Myblueheaven Living Aboard 0 02-28-2005 10:35 AM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising 0 02-28-2005 10:34 AM
Fuel Tank Niagara 35 Pcoastyoc Gear & Maintenance 1 10-24-2004 08:21 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
