Old 07-13-2007
vwell is on a distinguished road
Motor-sailing and Transmission Damage?
Just found out yesterday that it seems I'm having transmission problems on a new (400 hrs) transmission. The problem (hesitation shifting into forward) seemed to emerge after a day spent motorsailing downwind to save time and avoid going wing-and-wing. Any chance that that could have damaged my transmission or clutch?
Old 07-13-2007
FrankLanger is on a distinguished road
If by "motorsailing" you mean running your motor in gear while having sails up, I can't see any reason why this alone should cause you any trouble--many of us do this at various times for lots of reasons.
There are lots of knowledgeable people on this site who can provide good advice, but the first things I would check (because it's easy) is the fluid level in the transmission (ie. not to high or too low), the condition of the fluid (ie. nice pink colour, not black or smelling burnt) and the gear shift cable tension (ie. does it firmly move the shift lever on the engine all the way forward--a simple adjustment here may make it shift properly).
Good luck!
Frank.
Old 07-13-2007
vwell-
Motorsailing is a fairly standard practice for most monohulls... so that shouldn't have damaged your engine, unless you were sailing forwards and had the engine in reverse...
It would help if you said what kind of boat, engine and transmission you had... that would open up the possibility of a few equipment specific problems.
P.S. A word of advice...the more complete the information you give about a problem, the more likely you are to get a good answer back... garbage in ----> garbage out...
Old 07-13-2007
pigslo's Avatar
pigslo is on a distinguished road
Have you changed the fluid?
Old 07-13-2007
Thanks for your input. We have a Cal 31 with Universal 30 hp diesel, install Fall '05. A few weeks ago we noticed a hesitation shifting into forward, although reverse was fine. The problem seemed most pronounced when the engine was cold. After motoring a few minutes the problem would largely disappear. A friend and I wondered if it was a shifter linkage issue, however after disconnecting the linkages and manually moving the transmission's lever the problem still persisted. About that time we'd motor-sailed from San Francisco down to Santa Cruz, including a several-hour stretch straight downwind with a strong following sea. It was a pretty intense ride, and as I puzzle this out I'm wondering whether something could have happened to make this problem worse.
Thanks for considering this.
Old 07-14-2007
rcarr is on a distinguished road
What kind of transmission do you have? A dock mate of mind has a Hurth transmission that had the same problem. The troubleshooting guide in the Hurth manual gave the following procedure;
Drain the transmission and replace fluid with one quart of diesel. Run engine for three minutes at idle while engaging forward and reverse at ten second intervals. Stop engine, drain diesel, and refill transmission with fluid
This corrected the problem.
Hurth Transmission John & Heather Newport 4 01-12-2007 10:09 AM
Transmission Heat Exchanger gconley Gear & Maintenance 7 11-05-2006 09:45 PM
transmission question almostbroke Gear & Maintenance 8 06-05-2004 01:06 AM
Transmission Engages while in neutral...? kmeeks Gear & Maintenance 1 02-18-2004 09:56 AM
Breakdown in Paradise Mark Matthews Gear and Maintenance Articles 0 04-29-2002 08:00 PM
