07-13-2007
Full-time Cruiser
Like any other anchor, the Fortress and the Guardian are great for certain conditions. They happen to be good in medium or soft mud, and soft sandy bottoms. Grassy, rocky, hard mud/clay - not worth much. Since your cruising grounds are the Chesapeake, I'd go with the Guardian, or the West Marine danforth-style anchor. Both are significantly cheaper than the Fortress, and in the same conditions can work well or better - as much or more holding power.
With any of these, be carefull with how much chain you use. In soft mud, too much chain will actually cause the shank to sink into the mud, keeping it at roughly the same angle as the flukes - so it may not set properly at all. I think if you read the pamphlet that comes with a Fortress or Guardian, when they say 6, 12 or 15 feet of chain - don't go for the old "well, more should be better" mentality. But if you never anchor in muddy bottoms, you may never see that problem.
Caveat Emptor...
Cap'n Jon
KB1HTW
S/V Beausoleil
1979 Formosa 51 Ketch
Homeport: Marblehead, MA USA
