07-14-2007
I think you'd be better off using a small air compressor or pump to keep the damn thing inflated and then quickly glassing over the tubes...  Turn it into a fiberglass dinghy. Keep it inflated until the fiberglass cures. Then cut a small hole in the fiberglass and through the inflatable cloth and pour foam in to the opening....then glass over the hole after the foam hardens.
A friend of mine got a dinghy that this had been done to down in the French Antilles or somewhere like that... I never laughed so hard when I first saw it—really ugly—but it worked pretty well for her.... It was built from a high-pressure, inflatable floor model, but all the inflatable bits were glassed over with a light layer of glass (a couple of layers of 2 or 4 oz as my best guess) and filled with foam.
