Old 07-14-2007
prariedog's Avatar
prariedog is on a distinguished road
Stick (mast) wiring
We recently purchased a 34' Hunter. The wires that come out of the mast at the bottom are short and have regular crimps on them not marine crimps.
We want to change the wiring so that it has ample length. Also there are 2 coax cables that go up the mast that are not used. One is probably for the vhf radio which has been cabbled using a new coax by the previous owner that goes up the port shroud cables. Hmmm.
The question is can I pull the exsisting wires out of the mast, with new wires atatched to the old ones?
I dont Want to start pulling wires really hard to find out they are just snapping inside the mast, which would a loose loose cituation.
Thanks in advance
Prariedog
http://livesailcam.net
Old 07-14-2007
RickLaPaz's Avatar
RickLaPaz is on a distinguished road
I think I'd securely attach an 1/8" or 3/16" diameter (slippery) nylon messenger line to the old cables first, and pull gently so the old wire doesn't part/break. Then lay out the new wires parralel to the mast in a straight line so that when you pull the messenger, someone else can feed the new wires in without a lot of twisting or kinks. Also, you may want to add an additional wire (or 2) just for future use. You never know what you may want to add later. Now's the time to plan ahead.......
Enjoy
Old 07-14-2007
Rick's suggestion is pretty good... but I would also recommend you leave a messenger line in the mast for future use.
Old 07-14-2007
deniseO30's Avatar
Lies about her age
using gravity to pull down rather then up is what we do when running wires, piping and stuff in our biz. the weight of the wire will help it go down rather then stress your messenger line pulling up. Of course if the mast is down it's surely easier!
Old 07-15-2007
Senior in age only
HankOnthewater is on a distinguished road
Additional question re mast wiring
I was about to post a question when I saw this thread.
I agree with the three previous posts.
What is the best way to secure wiring in an alloy mast? Some of the things to avoid:
* chafing and clanging of wiring inside the alu mast
* relieving any tension on the wires/cables
* upgradability (as per three previous posts)
* minimise ingress of moisture (is elimination of moisture possible?)
In the past I run a conduit or even two. But what is best way to secure such a conduit?
Hank
take care
Old 07-15-2007
The simplest way to secure the wiring in a mast and to prevent chafe, noise, is to install a wiring conduit, usually PVC pipe. Stainless steel pop rivets are a good, fast, and simple way to attach the conduit to the mast.
Old 03-10-2008
rugila is on a distinguished road
I don't quite follow this one.
If the conduit is inside the mast, how do you use the stainless steel pop rivets to attach it? (from outside the mast??)
Old 03-10-2008
Basically, you drill two holes, and use a piece of coat hanger or stiff wire bent into a hook shape to pull the conduit up against the side of the mast through one of the holes. Then you drill into the PVC through the second and install the pop rivet. Do this about every five or six feet and you'll have a nice safe conduit that runs up the mast to run cabling through. You can even drill into the conduit (before running any wiring of course) to make exits for things like spreader and steaming lights.
Old 03-23-2008
Probably I should try this out on a bit of drainage pipe before doing it on my mast.
However, any other's experiences are valuable.
Regarding the two holes, is it better to drill these side-by-side and plug up the one not used to secure the conduit with a rivet or sealant? Or to drill one above the other, say 3 inches apart which should enable using both to secure the conduit.
The latter seems to me to be the tidier option, and presumably the pairs of securing points could be spaced further apart then the single ones.
Old 03-23-2008
Never a bad idea to practice on something cheap and easily replaced...
BTW, coat the rivets with Lanocote or TefGel to prevent corrosion between them and the aluminum mast.
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
