  #11 (permalink)
Old 07-16-2007
sailortjk1's Avatar
Originally Posted by SailorMitch
My Pearson 27 had a Westerbeke 12B2 engine, and on that one the raw water pump was pretty accessible from the rear. One improvement I did make that you may want to consider is a Speed Seal. Check it out at Welcome to Speedseal. It replaces the back plate and those little screws that always end up in the bilge with a thick plate and 4 knurled knobs you can turn with your fingers. Don't know if it will help your situation or not, but check it out. Sure makes opening the back a lot easier.
I will look into this product.
I was thinking of getting thumb turn screws for the cover plate.
Courtney is My Hero
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 10:45 AM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
universal diesel impeller shaft morrell17 Gear & Maintenance 3 06-27-2007 10:43 AM
3JH2 Yanmar Impeller RickBowman Pacific Seacraft 2 03-09-2007 06:10 PM
Impeller change 4 a Westerbeke 21 GDEMING Gear & Maintenance 3 12-02-2004 08:40 AM
