Cooling Cabin - Page 2 - SailNet Community
post #11 of 23 Old 07-15-2007
Freesail99's Avatar
2 Solar vents, will do wonders in cooling the cabin down.
S/V Scheherazade
Freesail99 is offline
post #12 of 23 Old 07-15-2007
I agree.. but they don't do much for you at night, when you really need the extra cooling, when you're trying to sleep.
BTW, I have two solar vents on my boat... and they help keep it much cooler when she's at the slip all closed up and waiting for me to arrive.
sailingdog is offline
post #13 of 23 Old 07-16-2007
poopdeckpappy's Avatar
Originally Posted by wvnutt
I used this when I raced offroad, It wasn't bad for it's intended purpose, I'd set it up inside my sportz tent on my truck, when it was over, I'd strip down to shorts and cool down slowly, when it's 110-120 degs and your body is teetering on heat exhaustion, every little bit helps, would I try this on a small boat ? I don't think so, not unless you confine yourself to a single stateroom or a very small cabin
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #14 of 23 Old 07-16-2007
I33
BTU information please!
I could not find any information on this web site regarding the cooling capacity of this unit. Can someone provide a BTU/hour number for this? I don't know any other way to accurately compare two air conditioning systems.
Gil
s/v Truthsayer
I33 is offline
post #15 of 23 Old 07-16-2007
Maybe ice melt rate would be a more effective measurement with the KoolerAire unit....... :-)
essman is offline
post #16 of 23 Old 07-16-2007
PassionKid's Avatar
It would be a bit of work, but why not take advantage of the very water you are floating on? I've often thought of rigging up a form of rad / pump / fan system that will pump cool water through a rad from under the boat, and pass a fan through the rad - wouldn't this provide adaquate cooling? I'm sure there are boxed systems like this no? The power requirements would be very low (a small pump and fan combo), and you might even have enough of a temperature differential between the ambient cabin temperature versus the water temperature to condense moisture from the air?
PassionKid
PassionKid is offline
post #17 of 23 Old 07-16-2007
christyleigh's Avatar
I agree.. but they don't do much for you at night, when you really need the extra cooling, when you're trying to sleep. BTW, I have two solar vents on my boat... and they help keep it much cooler when she's at the slip all closed up and waiting for me to arrive.
The bigger, better, and of course more expensive solar/battery 24hr vents will run all night. I've been using them on all my boats for the last 15 years.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #18 of 23 Old 07-16-2007
Stan-
I've got two of the Nicro 24-hour solar vents on my boat... while they do move a bit of air at night... a Hella Turbo or Caframo Bora moves a lot more air, and is directed where the cooling (ie my carcass) is most needed, rather than the cabin in general.
post #19 of 23 Old 07-16-2007
Stan-I've got two of the Nicro 24-hour solar vents on my boat... while they do move a bit of air at night... a Hella Turbo or Caframo Bora moves a lot more air, and is directed where the cooling (ie my carcass) is most needed, rather than the cabin in general.
Just wanted to make sure he was aware of the different flavors of solar as there are still many 'solar only' daytime vents being sold. We also have always had a Hella 12v fan directed across the berth for cooling air movement and the 'white noise' we have become accustomed to needing. I have also set up a kind of 2 stage cooling system on our boats - the 'assisted passive' 24hr solar intake and exhaust, but when it gets Really Hot I would kick in the 12v Hellas strategically placed to move the air in and out faster in those same directions.
Stan
'Christy Leigh'
NC 331
post #20 of 23 Old 07-16-2007
Passionkid-
That's classic "chilled water" cooling/refrigeration. The problems on a boat are that first, you need power to pump the water all the time. Second, raw water is going to have all sorts of crud in it, which means filtering it, and attending to cleaning out the system from time to time. And then the usual problems with water pipes, leaks, electrolysis, clogging < g > but it certainly can be done.
hellosailor is offline
Adding ports to the cabin ChrisAndVero Gear & Maintenance 3 02-16-2007 10:46 AM
Cabin Cooling Radiators flicker Gear & Maintenance 3 11-21-2003 07:43 AM
Proper Cabin Lighting Tom Wood Gear and Maintenance Articles 0 02-24-2003 07:00 PM
Proper Cabin Lighting Tom Wood Cruising Articles 0 02-24-2003 07:00 PM
Proper Cabin Lighting Tom Wood Her Sailnet Articles 0 02-24-2003 07:00 PM
