Old 07-15-2007
wildcard is an unknown quantity at this point
Where to measure a winch at?
I assume it is at teh narrowest point on the drum, correct? I have realy realy old ones and can not fine info on them and would like to replace them with new self tailers of the same size. Thanks in advance!
Old 07-15-2007
pigslo's Avatar
pigslo is on a distinguished road
The winch makers all have charts that will tell you what size you need base on how big the sails are in sg ft.
pigslo
Old 07-15-2007
Lewmar has a nice winch size calculator...and you can always go up a size if you think the measurements they've given you are wrong. BTW, most modern winches aren't generally measured in diameter...but in gear ratios.
For example: a Lewmar 40ST is a dual speed winch with a high-gear-ratio of about 40:1, the Lewmar 8 is a single speed winch with a 8:1 mechanical advantage.
Old 07-15-2007
I have a Barient #4s Im thinking that means 4 inch drum but I have yet to find any real info on them.
Old 07-16-2007
LOL... Barients aren't modern winches in that sense... they don't size them by gear ratio. Use the lewmar winch sizing guide. It is available here.
Old 07-16-2007
Are hand carved stone winches of any value?
As always, thanks for the help.
Old 07-16-2007
They make great paper weights...
Old 07-16-2007
PersevereF28R is on a distinguished road
You're still using paper?
Old 07-16-2007
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Try using an I-phone to wipe your @ss
Old 07-16-2007
For certain things, there is no high-tech substitute... Xort has a good example...
It's Winch Servicing Time Tom Wood Gear and Maintenance Articles 0 10-17-2002 08:00 PM
It's Winch Servicing Time Tom Wood Her Sailnet Articles 0 10-17-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
Titan’s Viper Series Winch Handle Dan Dickison Gear and Maintenance Articles 0 10-05-2000 08:00 PM
Titan’s Viper Series Winch Handle Dan Dickison Racing Articles 0 10-05-2000 08:00 PM
