07-16-2007
You may have to look at salvage parts as a possible source, or custom machined parts. Of course, it really depends on how the rudder your designing is attached to the boat... a spade rudder doesn't use pintles or gudgeons... I've also seen home-built boats that use the stainless steel tubing for the rudder stock as part of the mounting system.
