- Quick Menu
07-17-2007
Replacing wood "curtain" with wood door in head area? Catalina 27
Hi -
My 1976 Catalina 27 has a wooden "curtain" that closes off the head. The rails along the top have come loose from the headliner, so the curtain just flaps...
Anyone know if I find a pre-made door (teak?) that I can just bolt into place on there? Just attach hinges on the bulkhead, and presto?
Thanks
Phillip
07-17-2007
Space cadet
I don't have an answer for you, but you might try posting to one of the Catalina 27 e-mail lists.
07-17-2007
SENIOR CHIEF
Why not build yourself one? How hard could it be? Personnally I would use mahogany. I think it is prettier and cheaper...
07-17-2007
Purveyor of Fine Ideas
I dont see why you couldnt just put on hinges and hang a door made of marine-grade plywood as a quick fix. It doesn't have to look the best, just functional. Obviously the curtain wasn't offering any structural support anyway, so you wouldn't have to worry too much about the door carrying load or anything. Just fashion a door, stain it so it matches (maybe a coat of poly and/or epoxy if you're paranoid of water delaminating the ply), maybe put some handles on it, maybe a latch, and get back to sailing!
07-17-2007
Do you have the swing room for a door? On many boats, a curtain was used, since there really wasn't sufficient space for a door to swing and still open enough to let a person through... Before going off and making a door, or even ordering the supplies for a door.... mock one up out of foamcore board or corrugated cardboard, and see what will work.
Also, you may have to leave the bottom of the door a bit above the cabin sole, especially if the cabin sole isn't completely level or flat.... so the door can swing properly.
07-17-2007
Ohhh, those are two good points. The door on my head has gaps at the top and bottom, because the sole and headliner are both curved.
If swing room is an issue, you might try measuring for a regular door, then slice it vertically up the middle to create a simple bi-fold door. Adds another set of hinges obviously, but it could work. You could even put the bi-fold door on a track at the top (like a closet door in a home), or, if you've left a gap at the top, just let it swing freely!
07-17-2007
on my '76, there is a door. wood door, with a full piano hinge.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
07-17-2007
CP-
Does the door on your boat go all the way to the overhead and all the way to the cabin sole??? Or does it cut a bit short on the top and bottom?
07-17-2007
its open about an inch @ the top @ bottom.
07-17-2007
I have been hanging doors in homes and commercial buildings for over 33 years, and make a very good living doing so. When you add in the idiosynchrosies that is a boat, the difficulty and time go up exponentially. This is not a project for the DIY'selfer, and even less so if you think that you are going to fabricate one from scratch and then install it. By looking at your pic, I personally would quote a price of $1,200.00 for the door, un -inished, plus another $500.00 for installation. Then you have the hardware and the varnish work to contend with. But those are L.A. prices--your mileage may vary............
Good luck,
Rick
| Thread Tools |
Search this Thread |
